tempora123
I have a resistor divider. It consists of two resistors which models have w and l parameters among others. I would like to run monte carlo dc analysis on this circuit and plot w or/and l of the mentioned resistors vs monte carlo run. How to do this? I save: Model Parameters info Elements info Output Parameters info Primitives Parameters info into raw file yet I don't find the component parameters inside the result file. Is it possible at all to show component parameters in ADE spectre simulation results?
Thanks for your inputs, L.S.
