Jul 20th, 2024, 11:34am
how to print component parameter value in simulation (Read 1111 times)
tempora123
Sep 16th, 2008, 4:54am
I have a resistor divider. It consists of two resistors which models have w and l parameters among others. I would like to run monte carlo dc analysis on this circuit and plot w or/and l of the mentioned resistors vs monte carlo run. How to do this?
I save:
Model Parameters info
Elements info
Output Parameters info
Primitives Parameters info
into raw file yet I don't find the component parameters inside the result file.
Is it possible at all to show component parameters in ADE spectre simulation results?
Thanks for your inputs,
L.S.
