Jul 18th, 2024, 4:31am
Error launching ncvlog (Read 4819 times)
dinac
Belgium
Sep 21st, 2008, 10:09am
I was trying to simulate a verilog-AMS, and make a symbol, but i occured error. (using version: ius_v5.7_qsr1)
ncvlog(64): 05.70-s001: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ncvlog: *E,AMSN64: Verilog-AMS not supported in 64-bit mode.
I guess the tool is automatically invoking 64bit, where do i locate this file, is there a Environment variable to be set?
dinac
jbdavid
Re: Error launching ncvlog
Reply #1 - Sep 21st, 2008, 10:10pm
the variable is either INCA_64BITS
or CDS_AUTO_64BITS
it might be easiest to use
  printenv | grep "64"
there are versions that support 64bits for ams
jbdavid
dinac
Belgium
Reply #2 - Sep 22nd, 2008, 3:04am
Thanks...
i found that by default the ncsim calls from the 64bit directory of $AMSHOME/tools/bin/64bit/
And i see no ncsim.exe.. files  in /32bit directory, i see them only in /64bit directory
But i found the version " ius_v6.11" I read that this supports 64bit. so now i am using this version in a 64bit machine. To use this i dont even have to set the 64 bit.
But i am using icfb in 32bit . hope that is ok?
Joeyao Chou
Reply #3 - Nov 23rd, 2015, 7:05am
I think the programmer of this tool must misunderstand the Cadence environment variable CDS_AUTO_64BIT.
In order to run 32 bit ncvlog, you need to unset this variable, i.e.
unsetenv  CDS_AUTO_64BIT
BTW, set it to NONE or any other value does NOT work.
Just unset this variable.
