First off, I am assuming that you are running your simulation using Spectre. With that, you can save device parameters for the transient sim. The format is
Code:save X:param
where X is the hierarchical name of the device and param is the parameter you want to save. If you use
X:oppoint, it saves all of the parameters of the device, but you can save individual parameters as well.
I have not figured out how to do this through ADE. What I have done in the past is to create a file with the
save command, and include that file through ADE. That works just fine even if it is a bit bothersome. I should note that I haven't tried too very hard to figure out if there is another way.
