idriss
Hi jbd Thank you very much for the tip,it works perfectly,but the thing I didn't find any litterature about this system function $system even in the verilog manual,where can I find a complete list of systeme function of verilogams do you know that.
I have an other question jbd: you see I would like to define timescale like this
`timescale time_unit/time_accuracy so when i will be in a always block when I have a delay I just need to do #(delay/time_unit)..... So I can do like this
`define time_accuracy 1fs `define time_unit 1fs `timescale `time_unit/`time_accuracy
but the problem time_unit is in fs or delay has to be divided in f and not in fs,becasue it's a real parameter. do you have an idea how to get ride of the s in order to use with delay .
Regards Idris
