Jul 19th, 2024, 6:32pm
How to simulate fully differential opamp? (Read 242 times)
holddreams
Oct 10th, 2008, 4:00am
Does anyone who has ever used balun to simulate fully differential opamp with SC CMFB?
For DC Gain analysis, how to build up the test bench?
EE240 has one slide like that(DC_Gain_Bias, as in the attachment1).
The SC CMFB is introduced in Ken Martin's book(cmfb,as in the attachment2).
Here comes my questions:
1)How to deal with the SC CMFB during AC analysis? That is, how to connect non-overlapping clock(ph1,ph2)?
2)How to deal with the Vbias in the attachment2?
Thanks.
holddreams
Re: How to simulate fully differential opamp?
Reply #1 - Oct 10th, 2008, 4:02am
The attachment 2.
Online
Reply #2 - Oct 10th, 2008, 3:38pm
SpectreRF's PAC analysis.
holddreams
Reply #3 - Oct 10th, 2008, 8:53pm
Ken Kundert wrote on Oct 10th, 2008, 3:38pm:
Thanks.
Is there any other way without using PAC analysis?
holddreams
Reply #4 - Oct 29th, 2008, 7:06am
I have write a verilogA module to replace the SC CMFB part and run the AC simulation, the results seems to be reasonable. Smiley
subgold
Reply #5 - Nov 12th, 2008, 4:11am
holddreams wrote on Oct 10th, 2008, 8:53pm:
Thanks.
transient simulation would do.
Tlaloc
Dallas, TX
Reply #6 - Nov 12th, 2008, 8:29am
Whenever I want a simple AC, STB,  or XF with the SC CMFB, I break the feedback from the SC CMFB and replace it with a continuous time CMFB model.  This gives me a very fast way of verifying the differential signal path of the amp.  Since I am normally making switched cap circuits anyway, I can verify the operation of the SC CMFB at a higher level where the time penalty of running a PXF or PSTB is already going to be spent.
idesign
Reply #7 - Feb 22nd, 2009, 2:08am
holddreams, is it possible you post the verilog-A of SC CMFB? tahnks
