Jul 21st, 2024, 3:14am
HSPICE model file loading issue in SPECTRE (Read 1759 times)
nube_human
T.O.
Oct 15th, 2008, 9:35pm
I am trying to load an HSPICE model file in a SPECTRE simulation. I have successfully done this in the past with
simulator lang=spectre
However this file has a
.prot
<encrypted>
.unprot
construct, and results in a syntax error due to encrypted portion.
Any ideas on how to get it to work.
Thanks in advance,
NH
-- NH
Re: HSPICE model file loading issue in SPECTRE
Reply #1 - Oct 16th, 2008, 9:47am
I doubt you can do anything about this -- not likely that Synopsys is going to give Cadence Synopsys's decryption key.  Not only because they are competitors, and Synopsys wants you to buy HSpice, but what if Cadence "accidentally" disclosed the key?
