holddreams
The following is a hspice format netlist.
$gm/id vs. gate overdrive .param gs=1
vds d 0 dc 1.5v vgs g 0 dc 'gs' mn1 d g 0 0 nch L=0.35um W=10um
.op .dc gs 0.4v 1.2v 10mv
.probe ov =par('gs-vth(mn1)') .probe gm_id =par('gmo(mn1)/i(mn1)')
.options post brief .lib './ee214_hspice.txt' nominal .end
Then how to convert the above to spectre format? If use spp -convert <test.sp> test.scs, the .probe ......will not be convertered. Also if in the spectre format netlist, say test.scs, adding simulation lang=hspice ... simulation lang=spectre ...
it still doesn't work.
Is there a simple way realize this? Cause not all companies has the license of hspice, and I don't know how to measure thing like this .probe gm_id =par('gmo(mn1)/i(mn1)') directly!
Your helps will be great appreciated.
