Jul 17th, 2024, 12:28am
[q] how does verilog-A work in DC sweep? (Read 5948 times)
kidhyun
Oct 21st, 2008, 2:08pm
   I have a question on the behavior of veriloga block in DC analysis. (DC sweep)
   I have a veriloga block which looks like the following.
   module X(in,out);
   real var1;
   analog begin
             @(initial_step)
                      var1 = 0;
   My question is if I do DC analysis sweeping 'in' voltage from, let's say, 0 to 1V with the step size of 0.1V, is 'initial_step' block called every time when the simulator runs DC analysis (11 times)? or Is that 'initial_step' called only when 'in' voltage is 0V (only at the start point of DC sweep)?
   (I only ran veriloga block with transient analysis, so I am a little bit confused.)
Thank You
solidstate
Munich, Germany
Re: [q] how does verilog-A work in DC sweep?
Reply #1 - Oct 22nd, 2008, 5:48am
I know that for e.g. an AC sweep over temperature, it processes the initial_step for every point of the sweep, so that should work for you too. Also, things like this are easily checked by adding something like $strobe("test") to the code that executes at an initial_step.
Reply #2 - Oct 22nd, 2008, 6:49am
According to the Verilog-AMS Language Reference Manual, version 2.3,
 @(initial_step)
only fires on the first step of a dc sweep; see Table 5-1 in Section 5.10.2, Global events.
This particular behavior was standardized in LRM 2.2; LRM 2.1 did not have a column for a dc sweep, so the behavior may not have been consistent in different simulators.
