I think you need to use the predefined macro, __VAMS_ENABLE__. See page 239 of the VAMS 2.3 LRM at,
http://www.verilog.org/verilog-ams/htmlpages/public-docs/lrm/2.3/VAMS-LRM-2-3.pd...Verilog-AMS HDL supports a predefined macro to allow modules to be written that work with both IEEE
std 1364-2005 Verilog HDL and Verilog-AMS HDL.The predefined macro is called __VAMS_ENABLE__.
This macro shall always be defined during the parsing of Verilog-AMS source text. Its purpose is to support
the creation of modules which are both legal Verilog and Verilog-AMS. The Verilog-AMS features of such
modules are made visible only when the __VAMS_ENABLE__ macro has previously been defined.
Example:
module not_gate(in, out);
input in;
output out;
reg out;
`ifdef __VAMS_ENABLE__
parameter integer del = 1 from [1:100];
`else
parameter del = 1;
`endif
always @ in
out = #del !in;
