Not sure what "cdsbarry" is - ah, I assume you meant "cdslibrary".
You didn't say which Design Management tool you're using. My guess is that it might be VersionSync - if so, are you expecting the "vault" to be within the library? Normally that would get created when you check it in - as a directory called ".VSVAULT" within the library. Worst case you can create the directory yourself, but it should not be necessary.
Some clue as to which tool you're using, and the error you are seeing would help diagnose the problem!
