jbdavid
If you use spectre for your analog, you need AMS.. I don't think you need NCSIM license, as long as you have enough MMSIM tokens available (AMS needs 3 tokens) you do need an AMS environment license.
Otherwise you are stuck with command line simulation, and you need the right analog simulator ( or other technology) to simulate the digital with the analog.
SNPS has a mixed signal simulator, (nanosimVCS) there might be an ADE interface for it.. but you would need to purchase it from SNPS not from Cadence..
good luck..
