Jul 17th, 2024, 2:38pm
how to model a vccap? (Read 1480 times)
ricky
Nov 24th, 2008, 11:16pm
hello,everyone
I am a beginner of verilog-a.I am working on a CDC(cap to digital converter).i need to model a vccap. this is my code:
   module c_module(c_p,c_n,vp,vn);
    inout c_p ,c_n,vp ,vn;
    electrical c_p,c_n,vp,vn;
    parameter  c0=1.0;
    real c;
    analog begin
            c=c0*V(vp,vn);
            I(c_p,c_n)<+c*ddt(V(c_p,c_n));
but error found by spectre as follows:
   an operand dependent on the output of a dot() operator (dynamic expression) can not be used in a multiplication opeeration when the other operand is dependent on a probe or the simulation time.
consider using a node to hold the dynamic expression and probe this node in the multiplication operation.
thanks for your help!
ricky
Re: how to model a vccap?
Reply #1 - Nov 25th, 2008, 3:43am
This has been covered already in this forum (and elsewhere), but it's faster to fix your code than to find the reference:
   analog begin
           I(c_p,c_n) <+ c0 * ddt( V(vp,vn) * V(c_p,c_n) );
The current is ddt of the charge, q=CV; since both V's depend on time, you need both inside the ddt.
Frank Wiedmann
Munich, Germany
Reply #2 - Nov 25th, 2008, 4:14am
ricky
Reply #3 - Nov 25th, 2008, 6:32am
thanks a lot!
ricky
Reply #4 - Nov 25th, 2008, 7:18pm
hi Geoffrey_Coram,
i think that i made a mistake in my describing. Embarrassed
my vccap is a four teminals device,and (vp vn) is a control signal which is  irrelevant to (v_p,v_n).
i can find a four teminals vccap model in CADENCE analogLib,but sadly i find this model cannt be set any CDFparameter.  why about this?
please forgive me for my trivial question and thank you for any help.
ricky
Peruzzi
Reply #5 - Nov 26th, 2008, 6:12am
Ricky,
Begin by describing the vccap mathematically.  Don't worry about modeling language yet.  What is the capacitance between vp and vn as a function of the voltage on the control inputs?
From there on it's easy:  Look up the correct syntax for cap = f(controls), then write the differential equation for the current through vp to vn as a function of the voltage across vp and vn.
CAVEAT: Avoid any mathematical step on the control voltage or you will run into convergence difficulties.  That's easy too.  If you own the model which drives the control voltage, drive the control voltages with the transition() function in that model.  If not, there are several other ways to avoid the infinite slope of a step in your vccap model.  (Read Ken K's book!)
Best regards,
Bob P.
Peruzzi
Reply #6 - Nov 26th, 2008, 6:25am
Ricky,
On second thought, don't worry about voltage steps on the control inputs.  It would be better to use transition() on the capacitance evaluation, to avoid any mathematical steps of the capacitance.
Bob P.
