Jul 17th, 2024, 6:32pm
Truly bidirectional ideal transformer in Verilog-A (Read 3788 times)
gmork_0
Prague
Nov 27th, 2008, 2:30am
In Spectre, there is an ideal transformer component (called transformer). This one is "truly" bidirectional - one can force the current or voltage (connect ideal current or voltage source) to either primary or secondary winding.
i just wondered, if such a component can be written in Verilog-A as well.My best try was:
module idealTransformer(pLeft, nLeft, pRight, nRight);
 parameter real ratio = 2 from (0:inf);
 inout pLeft, nLeft, pRight, nRight;
 electrical pLeft, nLeft, pRight, nRight;
 analog begin
     V(pRight,nRight) <+ ratio*V(pLeft, nLeft);
     I(pLeft,nLeft) <+ -ratio*I(pRight, nRight);
,what works fine for real loading of ports. However, one cannot e.g. connect the ideal voltage source to the pRight, nRight ports.
Thanks for comments,
Miro
Re: Truly bidirectional ideal transformer in Verilog-A
Reply #1 - Dec 3rd, 2008, 5:34am
I replaced your V line with an indirect assignment:
V(pRight,nRight) : V(pRight,nRight) == ratio*V(pLeft, nLeft);
and it seems to work with a v-source on either side.
