Aug 15th, 2024, 10:58am
how to run STB analysis with initinal condition (Read 4623 times)
microant
China,SH
Dec 03rd, 2008, 11:29pm
Hi all
I want to run STB analysis in analog deign enviorment with initial condition, while, when I set some net with init value  and check the output operation point, I find that the inital condition does not work.
Could anyone tell me how to add the initial condition when run STB analysis? thanks!
BR,
Lin   Tongue
microant
China,SH
Re: how to run STB analysis with initinal condition
Reply #1 - Dec 8th, 2008, 7:25pm
is there anyone know how to do it? thanks
B,R
Lin Sad
Reply #2 - Dec 8th, 2008, 9:56pm
microant wrote on Dec 3rd, 2008, 11:29pm:
Use "prevoppoint=yes" or "readns".
microant
China,SH
Reply #3 - Dec 17th, 2008, 11:43pm
Hi pancho_hideboo
Thanks for your help!
I read the help for Spectre and try as you said. when I set  "prevoppoint=yes" and add initial condition in the ADE, the OP is still not change. about the option 'readns', could you tell me how to setup it?
BR,
Lin
ACWWong
Oxford, UK
Reply #4 - Dec 18th, 2008, 12:05am
The way i would do this is:
1) set the order of simulation as dc stb (in ADE its Setup-> Analysis order)
2) in the dc options form click "force" to "all". This will make DC analysis force the initial conditions you set up in the schematic i.e. your initial conditions (Setup->Convergence Aids-> etc.)
4) in the stb options form click "prevoppoint" to "yes". this will now take the dcOp from the previous dc simulation which has been forced into taking the initial conditions
hope this helps
aw
microant
China,SH
Reply #5 - Dec 18th, 2008, 6:53pm
Hi aw
thanks for your help!
I've got it as your suggestion.
BR,
Lin
