Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 19
th
, 2024, 12:19pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› How to plot the sweep variable of an ac sweep with ADE calculator
Previous topic
Next topic
How to plot the sweep variable of an ac sweep with ADE calculator (Read 6044 times)
mlujan1965
Dec 12
th
, 2008, 3:36pm
I am doing an ac sim at one frequency using a design variable
as the swept parameter. How do I refer to this design variable (what syntax) in the ADE calculator so I can use it in a plot equation
IP Logged
Re: How to plot the sweep variable of an ac sweep with ADE calculator
Reply #1 -
Dec 13
th
, 2008, 12:42am
Use VAR("variable_name").
If this is not suitable for your purpose, use Result Browser.
If you can't get results you desire in Result Browser, see the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1214321363
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
mlujan1965
Reply #2 -
Dec 15
th
, 2008, 1:51pm
Thanks Pancho:
Using VAR("variable_name") only plots the static
value the variable is set to in ADE. I am using this variable as the
sweep value in an ac sim.
Ex. I have a variable gain cell whose gain is controlled with a control
current "Igain" I do an AC sim at 100Hz using Igain as the sweep
variable. I can plot the cell gain (which is vs. Igain in the
waveform window). I also want to plot this gain minus a multiple
of the sweep variable Igain to access the linearity of the gain char.
vs Igain but I don't know what to call the sweep variable Igain
in the calculator.
IP Logged
ACWWong
Oxford, UK
Reply #3 -
Dec 15
th
, 2008, 2:20pm
you need xval() which gets the swept variable in an ac sweep. its available in the calculator.
so in calculator you could use for example:
xval(VF("/anynetname")
would be used in the expression you want.
cheers
aw
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
