I could find no record of this being reported by anyone else, so hard to diagnose (especially over a board like this). I'd advise contacting your local customer support to help you with this.
A quick question though - can you run natively on a Linux machine (i.e. with a local x-server, rather than via a PC X-display program). It's quite possible that there is some interaction between the Java implementation on Linux versus that on Solaris, and the X-display program (XWin) that you're using - so it still could be due to the X-Server. It's a wise idea to test this.
Also, perhaps try with (say) vnc, to see if it happens there?
