Jul 19th, 2024, 12:35am
Problem in Print Setup Form of Cadence Wavescan (Read 2301 times)
Jan 6th, 2009, 7:41pm
In my environment, buttons of "Print" and "Cancel" don't appear in Cadence Wavescan.
I think this is due to widow manager problem.
I use "fvwm 2.5.21" in Cygwin.
Is there anyone who knows methods to show these two buttons in fvwm2 ?
« Last Edit: Jan 06th, 2009, 11:01pm by pancho_hideboo »
Re: Problem in Print Setup Form of Cadence Wavescan
Reply #1 - Jan 23rd, 2009, 3:20am
My X-Server is XWin of Cygwin on MS-Windows XP.
Window manager is "fvwm 2.5.21".
If I execute Wavescan from Linux client, buttons of "Print" and "Cancel" don't appear in Cadence Wavescan.
But if I execute Wavescan from SunOS client, buttons of "Print" and "Cancel" appear surely. Attached figure is a result of Wavescan from SunOS client.
So it doesn't seem this is due to widow manager problem.
Is there anyone who knows solutions to resolve this problem ?
Reply #2 - Jan 23rd, 2009, 10:18am
I could find no record of this being reported by anyone else, so hard to diagnose (especially over a board like this). I'd advise contacting your local customer support to help you with this.
A quick question though - can you run natively on a Linux machine (i.e. with a local x-server, rather than via a PC X-display program). It's quite possible that there is some interaction between the Java implementation on Linux versus that on Solaris, and the X-display program (XWin) that you're using - so it still could be due to the X-Server. It's a wise idea to test this.
Also, perhaps try with (say) vnc, to see if it happens there?
