Jul 16th, 2024, 4:57pm
Problem in wavescan (Read 2783 times)
Rooney
Problem in wavescan
Jan 07th, 2009, 3:07am
while opening the wavescan, I am getting the following errors:
Error eval: undefined function - ddsProgramName
Error load: error while loading file - "..../.cdslocal"
Can any one please tell what does this error mean and how to resolve it?
Don't know whether this can be the issue for wrong waveform dumping.
Re: Problem in wavescan
Reply #1 - Jan 7th, 2009, 9:12am
I found some old solution which indicated that this error came about when using DesignSync - it calls this function to determine the executable. However, the "awd" executable (which is used for "ocean" and "wavescan" too) does not define this function.
A workaround is to add this to the beginning of your .cdsinit file (needs to be before any DesignSync code is loaded):
unless(isCallable('ddsProgramName)
    procedure( ddsProgramName()
    nth(0 parseString(nth(1 parseString(getVersion() " ")) "."))
    );procedure
You may possibly need it in an .oceanrc file as well, dependent on whether the code which is calling ddsProgramName() is loaded when running "ocean".
