Aug 19th, 2024, 9:46pm
hspice and K28.5 pattern (Read 182 times)
wwm101
china
Feb 03rd, 2009, 5:14am
how to use K28.5 pattern in hspice simulation?
thank you in advance.
View Profile wwm101 weiming022002@yahoo.com   IP Logged
Re: hspice and K28.5 pattern
Reply #1 - Feb 3rd, 2009, 6:34am
Are you looking for an independent voltage source that generates a K28.5 pattern?
Or do you have one, and you don't know how to use it in HSpice?
(I had to Google K28.5 to even have any idea what you were talking about ...  It's best not to assume that everyone here knows exactly what sorts of simulation you're doing.)
Reply #2 - Feb 3rd, 2009, 9:47pm
I also had to google K28.5. I think you need something like this in HSPICE:
* example of k28.5 repeating data pattern
v1 k28_5 0 pat (3 0 0n 1n 1n 5n b0011111010110000010 r=-1)
r1 k28_5 0 1
This means 3V high, 0V low, 0n delay, 1n rise and fall time, 5n for each sample, and then the k28.5 pattern. The r=-1 means repeat indefinitely. This is assuming that I found the right pattern from my google searches...
Spectre also has a similar bit source (see "spectre -h vsource" which can output bit sequences or reference named patterns).
wwm101
china
Reply #3 - Feb 4th, 2009, 4:40am
to:Andrew Beckett,Geoffrey_Coram
thank you very much.
