Aug 15th, 2024, 1:29pm
number of runs in Monte carlo simulation (Read 1415 times)
filipe
Brasil
Feb 10th, 2009, 2:40am
How to estimate the minimum number of runs in a Monte carlo simulation???
I heard that this estimation can be calculated based on the central limit theorem.
Filipe
View Profile filipe filipe   IP Logged
boe
Re: number of runs in Monte carlo simulation
Reply #1 - Feb 10th, 2009, 3:59am
Hi Filipe,
sigma/sqrt(N) is a measure for the accuracy of the average because averaging N normally distributed random variables reduces the standard deviation by a factor of sqrt(N). [Edit: derived from Central limit theorem]
BOE
« Last Edit: Feb 10th, 2009, 9:25am by boe »
vivkr
Reply #2 - Feb 12th, 2009, 12:16am
Maybe a more concrete number for you. Typically, we are trying to estimate the moments of the distribution for a given parameter (mean and standard deviation) within a certain confidence level.
As a benchmark, 100 runs of Monte Carlo will typically give +/-2% accuracy in estimation of mean, and +/- 14% accuracy in estimation of the standard deviation. Doubling the number of runs will improve the accuracy by sqrt(2).
Best regards,
Vivek
Reply #3 - Feb 12th, 2009, 1:20pm
Note also that spectre supports "Latin Hypercube Sampling" these days which tends to converge the standard deviation with fewer samples http://en.wikipedia.org/wiki/Latin_hypercube.
filipe
Brasil
Reply #4 - Feb 16th, 2009, 10:31am
Vivkr,
This is exactly my question. How can I calculate the accuracy of the mean and standard deviation? When can I find an explanation about it?
Thanks a lot
Filipe
vivkr wrote on Feb 12th, 2009, 12:16am:
Best regards,
Vivek
packiaraj
India
Reply #5 - Feb 27th, 2009, 6:09am
Filipe,
Guess you must have seen this link by now: Roll Eyes
http://www.financial-risk-manager.com/risks/market/mc_errors.html
The expression for error-in-"Mean" that you get from MC sims. BOE has indicated it almost correctly, though it is for only 1Sigma (~68% confidence-level in Normal Distribution).
Think we have to add this error-in-"Mean" to actual "Mean" when we say this is my Bandgap-output or Oscillator-frequency accuracy.
analogue_guy
Reply #6 - Mar 2nd, 2009, 12:43pm
filipe wrote on Feb 16th, 2009, 10:31am:
Vivkr,
Thanks a lot
Filipe
After running the Monte Carlos and collecting the results you can calculate confidence interval for mean,sigma.
One is based on Student-t deviation, the other is based on CHI-SQUARE deviation. You can find more details in every basic statistics books.
If you would like, I could look up the equations.
Cheers
AnalogDE
Reply #7 - Mar 19th, 2009, 4:43pm
analogue_guy,
Could you please send me or post the equations and/or a reference that has this information?  I'm also interested.
Thanks!
