Aug 14th, 2024, 11:31am
how to measure high order sigma-delta modulator? (Read 138 times)
zhujun134
Feb 16th, 2009, 6:48pm
Hi,everybody,
    I have designed a five order sigma-delta modulator,then i must have made a plan to measure it.But i have no experience about measure high performance IC.
    This chip  have a 16bit resolution and have 94dB SNR of simulation,have no built in  clock,have single input.I have some idea about issue must be attention:
 First,the input signal must  be clear,but how to get it ?can i get the signal by generator directly?
 Second,the clock must have little jitter than 100ps,but how to get  it?can i get it through generator directly?or use oscillator?
 Third,the power must be clear!
so much,are there have another issues?
many thanks!
Best regards!
View Profile 88206995   IP Logged
Re: how to measure high order sigma-delta modulator?
Reply #1 - Apr 15th, 2009, 8:30pm
It seems you have already known the key issues.
Measure your signal generator and judge if it is good enough for your SD modulator test. Good luck.
Yawei
