Visjnoe
Dear Manopidan,
1. Yes, in theory you should consider all harmonics 'upto infinity' to calculate THD, but in practice you can end the summation after the first n (n=3,n=5,n=10?) since the higher harmonics will have less and less power and eventually slide under the noise floor.
2. Sampling makes no difference. If your harmonic > Fs, than it will simply fold back into your baseband ([-Fs/2,Fs/2]).
3. Use an RF simulator if you can, you will gain a lot of simulation time versus the transient analysis approach.
Peter
