Jul 19th, 2024, 12:23pm
THD of Switched capacitor filter (Read 2731 times)
manodipan
Feb 17th, 2009, 3:36am
Hi friends,
I am simulating a switched cap filter operating at 10 MHz,now for THD calculation harmonics are to be taken upto what frequency??in continuous domain we consider upto infinity.but in this case output is sampled at 10MHz....thanks a lot...
manodipan
Re: THD of Switched capacitor filter
Reply #1 - Feb 17th, 2009, 4:24am
Hi ,
I have some more doubts......does amount of distortion has some relation to order of filter??
also for some spec of SC filter does suppose 2nd order distortion improve as we change the fundamental freq towards dc...what i have seen is that for suppose 300KHz cutoff ,better 2nd order distortion at 10KHz input than 100KHz  for same amplitude of input signal....
subgold
Reply #2 - Feb 18th, 2009, 4:12am
manodipan wrote on Feb 17th, 2009, 4:24am:
Hi ,
it will have some influence.
it is not good to choose the sampling freq as a harmonic of your input. try to use another input freq.
Visjnoe
Reply #3 - Feb 18th, 2009, 11:29am
Dear Manopidan,
1. Yes, in theory you should consider all harmonics 'upto infinity' to calculate THD,
   but in practice you can end the summation after the first n (n=3,n=5,n=10?) since
   the higher harmonics will have less and less power and eventually slide under the
   noise floor.
2. Sampling makes no difference. If your harmonic > Fs, than it will simply fold back
   into your baseband ([-Fs/2,Fs/2]).
3. Use an RF simulator if you can, you will gain a lot of simulation time versus
   the transient analysis approach.
Peter
