Jul 17th, 2024, 2:16am
look up table in verilog-A and spectre support (Read 16356 times)
rajdeep
UK
Feb 27th, 2009, 3:28am
I heard once that Verilog-AMS supports look-up tables. Can it be done in Verilog-A and does Cadence
Spectre support this?
If yes, can someone post me a small code section how a look-up table can be implemented in verilog-A?
Thanks much!
Rajdeep
Re: look up table in verilog-A and spectre support
Reply #1 - Feb 27th, 2009, 6:41am
$table_model is part of the Verilog-AMS LRM, so it should be supported.  Here's an example, copied from the LRM:
module example_tb(a, b);
  electrical a, b;
  inout a, b;
  analog begin
    I(a, b) <+ $table_model(V(a,b),"sample.dat");
and a completely fabricated data file:
#sample.dat
0 0
1 1
2 4
3 9
4 16
Reply #2 - Feb 27th, 2009, 6:57am
spectre has supported this for several years.
rajdeep
UK
Reply #3 - Feb 27th, 2009, 7:31am
Thanks a lot  Geoffrey! It's working!
I could not find this table_model in the Verilog-A LRM, so thought to ask about it straight away  in the forum, and as expected got a quick and effective reply.  :)
rajdeep
Reply #4 - Feb 27th, 2009, 8:16am
Rajdeep,
I assume you must be looking in the wrong LRM? If it's the VerilogA LRM that's shipped with the Cadence tools, then it's in IC5141's VerilogA Reference Manual, and all MMSIM versions.
rajdeep
UK
Reply #5 - Feb 27th, 2009, 9:19am
Hi Andrew,
I downloaded it from web couple of years back and still use that one.
It could be that the one that comes with Cadence is a more complete one.
thanks for your hint. I will try start using that one from now on..... Cool
Rajdeep
Reply #6 - Feb 28th, 2009, 9:59am
The Verilog AMS LRM is also on this site - look at the Verilog-AMS link at the top of the page...
Reply #7 - Mar 3rd, 2009, 6:49am
Indeed, $table_model was not in the Verilog-A LRM, nor in Verilog-AMS LRMs until version 2.2.  It was donated by Cadence, though, so it was likely in Spectre for a while before that.  You ought to get the latest LRM; it's free!
Dracon
Reply #8 - Mar 8th, 2009, 5:44am
And what if you want to use $table_model that could change your signal with frequency?
I know, you may say that laplace_nd function can be used but is there possibility to create linear changing attenuation?
Reply #9 - Mar 8th, 2009, 8:53am
Dracon wrote on Mar 8th, 2009, 5:44am:
What do you mean by "linear changing attenuation" ? Attenuation depending on frequency is linear value or dB value ?
If it is linear, show me example of dependencies of attenuation.
« Last Edit: Mar 8th, 2009, 10:16am by pancho_hideboo »
Dracon
Reply #10 - Mar 8th, 2009, 2:55pm
Yes you are right it is not linear, and this is not what I meant to write. What I want to achieve is to have some kind of impact on attenuation, in modelling cable for example, and express that as 2D look-up table(frequency, attenuation).
As far as I know the $noise_table is very flexible on this aspect but only for noise.
Reply #11 - Mar 8th, 2009, 3:11pm
Dracon wrote on Mar 8th, 2009, 2:55pm:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1227194040
