Aug 31st, 2024, 6:19pm
how to make a soft-start in charge pump (Read 285 times)
hdqkwr
Feb 28th, 2009, 1:17am
Hi,all:
In a charge pump DC-DC converter, how to make a soft-start in it?As in start up time, there is large inrush current exist in charge pump.I want to get some way to suppress it, is there any reference or any suggestion?
NiceFeng
Re: how to make a soft-start in charge pump
Reply #1 - Apr 12th, 2009, 5:11am
hdqkwr wrote on Feb 28th, 2009, 1:17am:
Hi,all:
Hi,hdqkwr,
  During start-up period, you could operate some of the power switches as current source, which means connected the gate voltage to a biasing voltage instead of Vdd/GND.
Feng
mengcy
Reply #2 - Mar 18th, 2010, 7:15pm
Hi, do you integrate a short circuit protection  or current limiting block on your chip?
If the answer is yes, you can reuse the protection circuit to control the startup current.
View Profile mengcy   IP Logged
RobG
Bozeman, MT
Reply #3 - Feb 22nd, 2011, 12:00pm
NiceFeng wrote on Apr 12th, 2009, 5:11am:
Hi,all:
Hi,hdqkwr,
Feng
This is easy to do... see Fig. 12 of Gregoire, "A compact switched-capacitor regulated charge pump power supply," JSSC, Aug 2006, 1944-1953
Kevin Aylward
Reply #4 - Jul 6th, 2013, 8:35am
Large RC time constant on the reference voltage to the converter.
Kevin Aylward
