Aug 16th, 2024, 12:18am
automated simulation of hysteresis (Read 8924 times)
analogue_guy
Mar 02nd, 2009, 12:38pm
hi
how do you simulate hysteresis behaviour automatically?
cheers
Re: automated simulation of hysteresis
Reply #1 - Mar 2nd, 2009, 10:40pm
The conventional way is to do a DC sweep in one direction, and then a second in the opposite direction. Spectre can do this simply by adding hysteresis=yes to the dc analysis (there's a checkbox on the dc form in ADE for this too). You can also just do two dc analyses, specifying the sweeps in different directions (from a netlist).
analogue_guy
Reply #2 - Mar 3rd, 2009, 4:35am
Andrew Beckett wrote on Mar 2nd, 2009, 10:40pm:
Thanks for the answer, formerly I used always transient simulation with a voltage ramp and I wanted a setup to run plenty of monte carlo runs and just keep the hysteresis window value after every runs.
Reply #3 - Mar 3rd, 2009, 10:04pm
Andrew,
I simulated hysteresis as analogue_guy did. A slowly rising/falling slope was applied to the input of DUT.
The DC hysteresis sweep is new to me. In my mind, the simulator solves the operating point of DUT in each step of a DC sweep independently. For eg., let the simulator sweep from 1V to 2V by 0.1V step. It will solve the operating point of 1.0V, 1.1V ... 1.9V, 2V respectively and independently. As well known, the hysteresis is not memoryless. The output is strongly decided by the previous state. How does spectre simulator solve this problem by DC hysteresis sweep?
Yawei
boe
Reply #4 - Mar 4th, 2009, 1:18am
Yawei, Quote:
... It will solve the operating point of 1.0V, 1.1V ... 1.9V, 2V respectively and independently. As well known, the hysteresis is not memoryless. The output is strongly decided by the previous state. How does spectre simulator solve this problem by DC hysteresis sweep?
Using solution of previous step as initial guess for next step reduces computation time and provides previous state.
BOE
Reply #5 - Mar 4th, 2009, 1:30am
That's right - the starting point for each point in the sweep is the previous point, and so you will generally see the hysteresis. Of course, if the hysteresis is based upon some capacitative charge storage, then DC won't do - but in many cases it's sufficient (and quick!).
analogue_guy
Reply #6 - Mar 4th, 2009, 7:57am
Andrew Beckett wrote on Mar 4th, 2009, 1:30am:
Yes, the DC sweep works, hysteresis function can be seen. But comparing the results with the transient results I can see that the circuit is less sensitive for statistical variations (using the MC).
But could you recommend me any technique to translate these results (either the DC sweep or transient) to only a number in every run (basically the difference between the two values) and I could deal only with these number afterwards.
At the moment I save the whole waveforms in both cases (DC sweep and transient). But it required more time, also post processing, so it is not that comfortable.
Cheers
boe
Reply #7 - Mar 5th, 2009, 1:25am
Analogue_guy,
You can use function "cross" to determine where the comparator output changes.
Is that what you are looking for?
BOE
analogue_guy
Reply #8 - Mar 5th, 2009, 12:16pm
boe wrote on Mar 5th, 2009, 1:25am:
Analogue_guy,
BOE
Thanks, I looked for this kind of solution. I will try to do so.
Cheers
