Aug 15th, 2024, 10:28pm
a question about corner simulation (Read 1783 times)
Lilylily
Mar 09th, 2009, 7:46am
During corner simulation,what does "fast nmos" or "fast pmos" mean?
If I set the section of mos "the ff",must I set the sections of bjt,res,cap and other devices "the ff" simultaneously? Thanks!
View Profile Lilylily   IP Logged
raja.cedt
Re: a question about corner simulation
Reply #1 - Mar 9th, 2009, 8:09am
hi,
   i feel it depends  strongly on the circuit.Lets say if you are using poly resistor it is independent on process,so in this case for any thing more or less you will get same result,whereas some circuits like biasing,less resistor  value  may gives worst condition.If you are not in a position to decide worst corner,do both simulations(fast nmos,less res and fast nmos ,high res).
Thank you,
Rajasekhar.
