Actually you should be able to do it with 4.3.4 (9502) to get to 4.3.X format, and then translate that using a version between 4.4 and 4.4.6 to get it into a database that can be read with IC5141.
Unless you've got software and hardware that can run these versions, I'd say it's going to be quite tricky.
