Jul 16th, 2024, 9:21pm
NCSIM in Cadence (Read 5102 times)
Prateek
Mumbai
NCSIM in Cadence
Mar 23rd, 2009, 3:50am
hi,  we have cadence in our college, but ncsim doesnt work on it, are there different versions of cadence, where on some there is nc sim installed and on some it is not.
If yes, can i still simulate verilog-ams file on it? and how
please answer.... Smiley
it will be very helpful
View Profile Prateek blm_psm   IP Logged
Re: NCSIM in Cadence
Reply #1 - Mar 23rd, 2009, 10:07am
Verilog-AMS models are simulated using AMS Designer, which is included in the "IUS" stream of software (called "LDV" in earlier versions). The simulator is invoked using ncsim (often launched from either ADE, or from the hierarchy editor plugin within Virtuoso, or from the command line).
If you want to use a Cadence mixed-signal simulator that supports Verilog-AMS, you'll need AMS Designer, and so you'll need access to "ncsim".
Reply #2 - Mar 26th, 2009, 6:09am
Are you using any AMS features?  You can run Verilog-A models in Spectre, without AMS Designer or ncsim.
