Aug 15th, 2024, 4:57pm
Skill script for eye diagram measurements (Read 12392 times)
avlsi
singapore
Mar 27th, 2009, 12:01am
         Can any one provide me the skill script for eye diagram measurements.
         Thanks in advance
Winners never Quit,Quitters never Win
Re: Skill script for eye diagram measurements
Reply #1 - Mar 27th, 2009, 3:17am
avlsi wrote on Mar 27th, 2009, 12:01am:
I can't know what measurements you want to do. Simple aperture Ratio ? There are many measurements in eye diagram.
http://www.home.agilent.com/agilent/product.jspx?cc=US&lc=eng&ckey=1486728&nid=-...
Page-30 of http://eesof.tm.agilent.com/pdf/ads2005a_whats_new.pdf
http://www.designers-guide.org/Forum/YaBB.pl?num=1209812189
You don't specify vendor's name of tools you use.
But if you use Cadence Design Environment and simply want to plot eye diagram, enter "ocnHelp 'eyeDiagram" in CIW.
Quote:
eyeDiagram ( o_waveform n_start n_stop n_period ) => o_waveform/nil
Description
This function gives an eye-diagram plot of the input waveform signal. It returns the waveform object of the eye-diagram plot.
Arguments
n_start : x-axis start value from where the eye-diagram plot is to commence
n_stop : x-axis stop value where the eye-diagram plot will terminate
n_period : period value
Value Returned
o_waveform : Returns a waveform object representing the eye-diagram plot of the input waveform
nil : Returns nil and an error message otherwise
Example
eyeDiagram( v("/out" ) 0n 500n 12.5n)
avlsi
singapore
Reply #2 - Mar 29th, 2009, 7:10pm
I am sorry with the ambiguity in my request.
I was able plot the eyediagram.
I am using Spectre as my simulation tool with the sub version 5.10.41
I need to measure the
     Eye Amplitude
     Eye Crossing Amplitude
     Eye Crossing Percentage
     Eye Height
     Eye Level
     Eye SNR
     Quality Factor
     Vertical Eye Opening
     Time Measurements
     Deterministic Jitter
     Eye Crossing Time
     Eye Delay
     Eye Fall Time
     Eye Rise Time
     Eye Width
     Horizontal Eye Opening
     Peak-to-Peak Jitter
     Random Jitter
     RMS Jitter
     Total Jitter
Thanks in advance.
Reply #3 - Mar 30th, 2009, 1:49am
avlsi wrote on Mar 29th, 2009, 7:10pm:
     Eye Amplitude
     Eye Height
     Eye Level
     Eye SNR
     Quality Factor
     Time Measurements
     Eye Crossing Time
     Eye Delay
     Eye Fall Time
     Eye Rise Time
     Eye Width
     Peak-to-Peak Jitter
     Random Jitter
     RMS Jitter
     Total Jitter
As you know, if you use Agilent Tools, all these measurements are prepared.
But in Cadence Environment, you have to create models for these measurements by yourself.
I have some models, but don't have all models for your measurements.
I don't know whether Cadence new waveform viewer, ViVA(Virtuoso Visualisation and Analysis) have these measurements.
« Last Edit: Mar 30th, 2009, 3:45am by pancho_hideboo »
avlsi
singapore
Reply #4 - Mar 30th, 2009, 10:49pm
Can u please share the models which you have.
Thank u very much.
Reply #5 - Mar 31st, 2009, 3:04am
You may find sourcelink.cadence.com solution 11395772 useful - this kind of calculation can be the basis of a number of eye diagram metrics. See also solution 11018920 which shows getting a histogram of edge crossings (you can get this by using 11395772 and the IC613 histo calculator function too).
avlsi
singapore
Reply #6 - Mar 31st, 2009, 3:56am
Thanks for the reference Andrew.
I am a beginner in the skill scripting. So, can u just jot the commands to make use of the above script.
I have done the steps like
1. load("abEyeHisto.il")
2. plot(abEyeHisto(VT("/output") 0 1u 2n 0.5 1))
According to my understanding i have given the inputs thinking as start=0;stop=1u;period=2n;threshold=0.5;risisng edge
The resulted plot is a single point .
Please let me know where i am going wrong.
Reply #7 - Mar 31st, 2009, 9:11am
You can make life simpler for yourself by calling
abRegEyeHistoSpecialFunction()
and
abRegEyeCrossSpecialFunction()
in the case of the eye cross code. This will register the two functions as special functions in the calculator (look in the Special Functions pulldown in the AWD calculator, or in the "User Defined Special Functions" choice in wavescan/ViVA).
Then you have a form to fill in to build the expression for you (I really should update the solutions to make this clearer).
However, the problem with your expression is that the last argument is not indicating a rising edge, but indicating that you want 1 bin - hence the single point. If you want rising edge, and 10 bins (say), it would be:
plot(abEyeHisto(VT("/output") 0 1u 2n 0.5 10 "rising"))
I think a later version of the code (not the one on sourcelink at the moment) automatically makes the waveform draw as a histogram - I'll aim to update the sourcelink solution too when I fix the comments.
avlsi
singapore
Reply #8 - Apr 1st, 2009, 2:24am
Thank u very much for the help Andrew.
I was able to register the eyeHisto and eyeCross user defined functions.
From the eyecross function the output is a plot between crossover point value and the no.of hits. The average function of the above plot gives me a average cross over point.
And by doing the standard deviation of the eyecross plot gives a rmsjitter value.
Can u please help me to find the
1.eye vertical opening
2.Rise time of eye
3.Fall time of eye
Eagerly waiting .
« Last Edit: Apr 2nd, 2009, 12:51am by avlsi »
avlsi
singapore
Reply #9 - Apr 3rd, 2009, 1:28am
How to plot the vertica histogram  of an eye diagram using the skill script.
Huh
