Jul 17th, 2024, 3:39am
VerilogA Syntax Question (Read 2166 times)
neoflash
Mixed-Signal
Designer
Apr 01st, 2009, 6:17pm
I read a code with:
(* desc="" *) integer AAA;
What is the meaning of (* desc="" *) ?
Neoflash
Re: VerilogA Syntax Question
Reply #1 - Apr 2nd, 2009, 4:59am
(* whatever *) is an "attribute" which is sort of like a magic comment; simulators that understand it can use it as a hint to improve performance, and those that don't should just ignore it.  The results of simulation should be the same.
desc and units are special attributes for Spice-like simulators that support Verilog-A; they tag the associated variable as operating-point information.  Spice built-in models (like BSIM3) have op-pt info such as gm, gds, etc. that you can print out or plot; these attributes give the same capability to Verilog-A modules.
