Jul 22nd, 2024, 4:28am
Cadence ADE Transient Sim Delay Time Parameter (Read 2770 times)
indysjl
Minneapolis
Apr 03rd, 2009, 8:04am
Is it possible to use negative values for the vpulse delay time parameter in transient sims in Cadence?
View Profile indysjl   IP Logged
Re: Cadence ADE Transient Sim Delay Time Parameter
Reply #1 - Apr 4th, 2009, 2:19pm
I don't know the answer - I'd normally just try it to find out, which presumably you can do fairly easily? (I'm sat at home, in Windows, and can't easily test, and there's little point me testing something you can just as easily test).
Reply #2 - Apr 7th, 2009, 4:16am
If not, wouldn't you get the same effect by setting delay = period + (neg_delay) ?
Reply #3 - Apr 7th, 2009, 6:56am
I decided to save indysjl a little effort, and tried it myself.
Negative delay values do work.
Geoffrey - it's not quite the same as your suggestion, because with a positive delay, the pulse does not start until after the delay has happened - so the behaviour is different at the beginning of the simulation. If negative delay weren't supported though, it would be a reasonable alternative.
I've attached a picture showing no delay, a negative (-5ns) delay, and Geoffrey's suggestion (25ns delay, since the period is 30ns).
