Jul 17th, 2024, 2:16am
VerilogA laplace_zp element convergency issue (Read 3787 times)
neoflash
Mixed-Signal
Designer
Apr 07th, 2009, 9:09pm
I have come up with convergency difficulty in hspice simulation with laplace_zp element.
It is an peaking amplifier and the simulation results looks good in AC simulation. However, in transient simulation it reports "internal time step too small".
Already tried method=gear option and still can't get it to work.
Please advice if you have better solutions.
Peruzzi
Re: VerilogA laplace_zp element convergency issue
Reply #1 - Apr 8th, 2009, 7:32am
Without knowing more details I can only take a guess, and suggest you look for step functions in voltages or currents.  Make sure you set initial conditions, or know and approve of their defaults.
Good luck.
Bob P.
www.RPeruzzi.com
patrick
Santa Rosa, CA.
Reply #2 - Apr 8th, 2009, 8:38am
If you are not using the 2009.03 release you should upgrade to it if possible. Also if you can post the circuit & va module we can take a look.
Patrick
neoflash
Mixed-Signal
Designer
Reply #3 - Apr 8th, 2009, 10:47am
I know it now. I screw up the polarity of the zero and poles.
AC looks right but transient is a mess.
