holddreams
How to run spectremdl about stb analysis?
I create a stb.scs file ,and run "spectre stb.scs", the result is correct, the loop gain, gain margin, phase margin are all right.
However, during the spectremdl simulation, errors come up: FATAL(CMI-2010):Assertion failed in file 'dfistrm.c' at line 266. FATAL (SPECTRE-21):Assertion failed. Aborted ${APPBINPATH}/${PROGRAM}"$@"0<&3
The stb.scs: ....................... ...................... itest (vp fb) iprobe stbAnalysis stb start=1 stop=1e9 dec=20 probe=itest
Alter_tt altergroup{ include "./model.scs" section=tt}
Alter_ff altergroup{ include "./model.scs" section=ff} ................................ ...............................
The stb.mdl: alias measurement stbrun{ run stbAnalysis }
foreach vdd from {3.3}{ run Alter_tt run stbrun as stbrun_tt
run Alter_ff run stbrun as stbrun_ff }
Another question is how to manage the mdl file in order to measure the loopgain, phase margin, gain margin directly?
Thanks in advance!
