Dec 15th, 2025, 8:17am
inductor model (Read 4401 times)
tideblue
inductor model
Apr 16th, 2009, 5:00am
  I found in my model file that the variation of inductor at different models could be up to +-15%.  And the parasitic resistance and capacitance are correlated(when Rs is max,Cox is min and vice versa)
  I can not find any theoretical explanation on the big variation of L and the correlation.
 Do you think these numbers are trustworthy?
rfmems
Re: inductor model
Reply #1 - May 15th, 2009, 12:17am
About the correlation, I suppose Rs is min, the metal width is max, thus the parasitic cap is max, if you still want the same inductance.
what do you mean by different models? Do you have different models for one inductor in your lib?
