Aug 18th, 2024, 6:21am
How to plot OP parameter with sweep variable in Spectre? (Read 2372 times)
Yutao Liu
Guangzhou, China
Apr 16th, 2009, 6:00am
Hello everyone,
I want to plot some parameters of operating point versus the variable that is swept in DC simulation.
And my method is setting dc analysis and running parametric analysis with a variable the same as the one swept in dc, and plot the wave with "result browser".
Is my method ok? And is there any other better ways to do it?
thanks a lot!
holddreams
Re: How to plot OP parameter with sweep variable in Spectre?
Reply #1 - Apr 16th, 2009, 6:43am
You can use spectremdl to realize it.
Reply #2 - Apr 17th, 2009, 7:11am
Or make sure that you have:
save *:oppoint
in your netlist (add this in an included "model file" if using ADE), and then do a normal DC sweep. This will save all operating point parameters for all (wildcarded) devices.
This will be quicker than doing a parametric sweep.
