Jul 17th, 2024, 12:35pm
how to write a verilogA code to generate a voltage source? (Read 1538 times)
liletian
MD
Apr 16th, 2009, 10:43am
Hi Guys
Can anyone tell me how to generate a voltage source from some data(no analysis equations), I attached the voltage source in the pic, any suggestions will be appreciated. Also, any suggestions on how to design an amplifier to amplify the pic DC signal, I want to get digital output out of the curve.
Re: how to write a verilogA code to generate a voltage source?
Reply #1 - Apr 17th, 2009, 4:05am
liletian wrote on Apr 16th, 2009, 10:43am:
If you use Cadence Spectre or Agilent GoldenGate, use "analogLib/vpwlf".
If you use Agilent ADS(RFDE), use "adsLib/VtDataset" or "adsLib/VtUserDef with adsLib/DataAccessComponent".
If you want to implement this source using Verilog-A, use $table_model() system function.
http://edocs.soco.agilent.com/display/ads2009/System+Tasks+and+IO+Functions
Design comparator and use it as Data Slicer.
liletian
MD
Reply #2 - Apr 17th, 2009, 9:20am
pancho_hideboo wrote on Apr 17th, 2009, 4:05am:
 Thanks a lot, I tried analogLib/vpwlf, it does works. I also tried Agilent ADS(RFDE), use "adsLib/VtDataset" or "adsLib/VtUserDef with adsLib/DataAccessComponent", but I did not figure out how to use it.if you do not mind, please explain more.
it will be greatly appreciated.
also, what is your mean of   "Data Slicer", can you explain more?
Thank you
Reply #3 - Apr 17th, 2009, 10:11am
liletian wrote on Apr 17th, 2009, 9:20am:
In Agilent ADS(RFDE), you can't use "analogLib/vpwlf".
Instead you have to use "adsLib/VtDataset" or "adsLib/VtUserDef with adsLib/DataAccessComponent".
If you want to use "adsLib/VtDataset", dataset must be ADS's Dataset, that is, "*.ds" file which is binary.
In your case, Dataset is "osci_mixer_new_bak.ds". Expression is "OUT".
If you use "adsLib/VtUserDef with adsLib/DataAccessComponent", you can use ascii file as datafile which can be shared with "analogLib/vpwlf". Usually I use ascii file of Generic MDIF style for this purpose.
http://edocs.soco.agilent.com/display/ads2009/VtDataset+%28Voltage+Source%2C+Tim...
http://edocs.soco.agilent.com/display/ads2009/VtUserDef+%28Voltage+Source%2C+Use...
http://edocs.soco.agilent.com/display/ads2009/DataAccessComponent+%28Data+Access...
See http://www.maxim-ic.com/appnotes.cfm?an_pk=3671
For $table_model() system function of Verilog-A, what error did you encounter ?
Did you specify $abstime as "table_inputs" of $table_model() ?
liletian
MD
Reply #4 - Apr 17th, 2009, 1:24pm
pancho_hideboo wrote on Apr 17th, 2009, 10:11am:
thank you so much, the verilogA code works now.
patrick
Santa Rosa, CA.
Reply #5 - Apr 17th, 2009, 5:36pm
Most simple use of $table_model to define a source, in this case a pulse:
`include "disciplines.vams"
module src(p,n);
   electrical p,n;
   analog V(p,n) <+ $table_model($abstime, {1,2,3,4,5}, {0,0,1,1,0}, "1CC");
Time is used as the lookup variable with the (x,y) data defined using arrays (you'll probably use a file). On the control string, 1 => linear interpolation, "CC" - constant extrapolation both ends.
Patrick
