Jul 17th, 2024, 8:33pm
CUVDNF: Could not determine discipline (Read 6729 times)
makelo
Hillsboro, OR
Apr 20th, 2009, 11:04pm
I am having trouble in AMS Designer with the error:
ncelab: *E,CUVDNF (./ihnl/my_lib/my_cell/schematic/verilog.vams,123|30): Could not determine discipline for this expression .
In spectre, I run my my simulation consisting of a mixture of spectre and Veriloga files with no difficulties.  However, when I switch the simulator to AMS, I get this error.  I looked at one other thread, that hypothesized this error to occur with veriloga discipline voltage vs electrical, but the answer was inconclusive.  I also seem to get it with other disciplines like logic.
I have tried changing the order of the hierarchy editor 'view list', and switched up the default connect rules, to no avail.
Does anyone have any guidance on how to avoid this error?  Is it a connect rules issue?
Makelo
boe
Re: CUVDNF: Could not determine discipline
Reply #1 - Apr 21st, 2009, 2:47am
makelo wrote on Apr 20th, 2009, 11:04pm:
The simulator cannot determine whether a connect module is required or not. Did you try Cadence error help:
> nchelp ncelab CUVDNF
B.O.E.
makelo
Hillsboro, OR
Reply #2 - Apr 28th, 2009, 4:38pm
The error goes away by changing all type Voltage I/Os to type Electrical.
Not the ideal fix, as I believe the type Electrical increases the information being tracked by the simulator which slows the simulation.
I have checked that the issue exists with both IUS6.2, IUS8.2 and with connect libs, ConnRules_5V_full, ConnRules_18_full.  Are there other connect rules that should be used with type Voltage?
Reply #3 - May 1st, 2009, 5:29am
It sounds like you need to use the resolveto keyword in your connectrules:
connect electrical,voltage resolveto electrical;
This avoids changing the I/Os and will only impact nodes where you are connecting voltage to electrical disciplines.
In practice I don't think it makes much difference to the simulator...
