Jul 18th, 2024, 9:16am
Question about the plot for gm/Id design methodology (Read 513 times)
Yutao Liu
Guangzhou, China
Apr 21st, 2009, 12:31am
Hi everyone,
I am confused about why the Vgs is set to be Vth+200mV when plotting gm*ro versus Vds.
first, why the Vgs should be Vth+200mV while ploting gm*ro versus Vds?
second, while sweeping Vds, the actual threshold voltage would change as well, how should I define the value of "Vth" in the "Vth+200mV"? And how should I implement this simulation in Spectre?
analogue_guy
Re: Question about the plot for gm/Id design methodology
Reply #1 - Apr 22nd, 2009, 3:10pm
I guess you want to bias your transistor in strong inversion, that is why you use Vth+200 mV. The standard textbook definition of strong inversion: VGS> Vthreshol + 6* Thermal voltage (kT/q).
If you want some safety margin, you will end up at Vthreshold+200 mV.
regards
