Jul 19th, 2024, 2:31am
Montecarlo Simulations for On-chip Process variations for 90nm Technology (Read 3290 times)
cmos.analogvala
India
Apr 25th, 2009, 10:31am
I want to analyse a circuit for on-chip process variations. Which all parameters of BSIM4 model file I should vary in Montecarlo simulations ? I think I should vary these five parameters: vth0, dl, dw, lpe0, K3.
Am I correct ?
For 90nm Technology what should be approximate sigma of pdfs of these parameters for on-chip variations ?
Plz Reply
CA
Re: Montecarlo Simulations for On-chip Process variations for 90nm Technology
Reply #1 - Apr 28th, 2009, 5:22am
I would expect the sigma is proprietary information of your foundry -- how mature is their process?  Also note that the foundry may want to tell you the sigma is much wider than it is in reality, so that you can't claim a wafer is out of spec and they should pay.
cmos.analogvala
India
Reply #2 - May 11th, 2009, 6:59pm
Thanks a lot for the guidance. I could get model file for MC from foundry.
-CA
cmos.analogvala
India
Reply #3 - May 11th, 2009, 7:10pm
A small query along the same line. Now that I have model files for MC, I want to incorporate correlation between neighboring transistors for Mismatch analysis. I could see an option to specify CC and transistor pairs in ADE/ Statistical Analysis. The question still remains what CC value should I give to the transistors located within the area of 60 lambda X 50 Lambda ? I understand this is also a proprietary information. However I just need a rough estimate.
My chip has two modules which are far apart and the modules are very small.  I need to consider the fact that all Module A transistors are identical. All module B transistors are identical. However, transistors of module A and module B are not identical.
Is CC=0.9 an for transistors in single module an educated approximation ?
mowiehowie
Reply #4 - May 14th, 2009, 1:45am
Hi, I got almost the same doubt.
The only document I got gives me a rule of thumb saying that the accuracy for a MC simulation is Δμ/μ [%] = 100*3.92*(σ/μ)(1/sqrt(n)).
Where n is the number of runs, Δμ/μ is the accuracy, and σ/μ is the deviation/mean ratio.
Okay, I can set the number of runs on the simulator but how do I set the sigma/mean ratio???  :-?
Thanks a lot.
