Jul 18th, 2024, 10:24am
Cadence waveform plot by script (Read 3447 times)
analogue_guy
May 07th, 2009, 7:50am
I just wondered if it is possible, that I make a "waveform layout" in wavescan/viva, I simply save it (.grf file, xml kind of description) and I reuse this file in Ocean scripts. So, I plot automatically the waveforms as it is described in this .grf file and then save it as a picture.
Cheers,
--AG
Re: Cadence waveform plot by script
Reply #1 - May 29th, 2009, 1:32am
You can use:
win=newWindow()
awvLoadWindow(win "/path/to/file.grf")
Note that the paths in the XML graph file need to match your simulation result location.
