Jan 30th, 2026, 8:20am
Pages: 1 2 3
can't plot any data (Read 31690 times)
apprentice
can't plot any data
May 07th, 2009, 7:37pm
Hi Gurus,
 I tried a rfExample - LNA simple from Cadence spectreRF simulator. However, I was not successful to even plot a single figure.
Simulation runs and shows ready.
But plot doesn't show up. please refer to the screen shot.
in case the jpg can't be posted, the message is :
"There is no analysis data found or selected."
thanks for any suggestion on what I should check and try.
Re: can't plot any data
Reply #1 - May 8th, 2009, 7:28am
What waveform viewer are you using?  Are you using ADE?  Can you see a results directory created by Spectre?
apprentice
Reply #2 - May 8th, 2009, 1:36pm
thanks for your reply.
I use analog design environment. Assume ADE is the acronym.
Looks like I don't have a result directory. Should it under .../spectre? same level as .../spectre/schematic?
I'm checking my environment variables - PATH, etc.
oermens
Reply #3 - May 8th, 2009, 7:00pm
After simulation, or even during, go to Results->Select and schematic should be one of the options. Sometimes the direct plot form doesn't load the results.
Your simulation directory is set from ADE->Setup->Simulator/Directory/Host or from the environment variable (in .cdsenv not in your path!)
asimenv.startup projectDir string "/some_folder"
Then your results are saved in /some_folder/cellname/spectre/psf
Don't mean to sound insulting, but did you actually *run* the simulation? You don't have a spectre.out file (output log) in your .../spectre/psf folder.
apprentice
Reply #4 - May 8th, 2009, 8:44pm
Thanks Oermens. Any potential solution/correction is welcome.
1 Do I need vi .cdsenv at the very beginning, i.e.,  before running icfb?
  vi the .cdsenv to include the project directory - .../lnaSimple (which has the sub directory .../schematic) .
   My current .cdsenv is a default one. no asimenv.startup as shown below:
"ddserv showWhatsNew string "4.4.3"
spectre.envOpts firstRun boolean nil
spectre.envOpts controlMode string "batch"
asimenv showWhatsNew string "4.4.3"
asimenv showWhatsNew string "4.4.6"
asimenv showWhatsNew string "5.1.0"
asimenv showWhatsNew string "5.0.0"
2. in my case, the cellname is lnaSimple
3. what I did is netlist and run and ADE show "ready" after 1 minute.  I guess I run the simulation.
4. confused by spectrRF document (page 257-258 ver5.1.41 nov.2005)
   setenv CDS_rfExamples 'cds_root icms'   (i'm using icfb. shall i change icmst to icfb? Does "cds_root" depends on my installation?
Shall I include the path to .cdsinit or .cshrc?
I tried in .cshrc with setenv PATH. but cause problem.
path = ( $MMSIMHOME/tools/bin  $MMSIMHOME/tools/dfII/bin \         $CDSHOME/tools/bin  $CDSHOME/tools/dfII/bin \         $CDSHOME/tools/java $CDSHOME/tools/java/bin $path )
I found no such directory like .../java. my installation shows  ../jre.
really confused by the environment.
thanks a lot for some hints!
oermens
Reply #5 - May 8th, 2009, 9:12pm
apprentice wrote on May 8th, 2009, 8:44pm:
You don't have to edit .cdsenv, you can set the project directory in ADE as I mentioned previously (Setup->Simulator/Directory/Host). In my case, I have all my results stored in /opt/simulation/ and when I run simulation using lnaSimple (for example), spectre will create the results folders in /opt/simulation/lnaSimple/... So you just have to specify the base directory of the simulation results.
Also are you setting your environment to append the .cdsenv file upon exit? you have alot of duplicate entries which can cause confusion when loading icfb. If asimenv.startup projectDir is not defined, spectre will use the default location which i believe is $PWD/simulation. You can refer to ../IC/doc/anasimhelp/anasimhelp.pdf for information about this and other analog environment variables that can be set in .cdsenv.
Firstly, what type of analysis have you set up? If your analysis pane is empty then no wonder you aren't getting results. Please attach your input.scs file from /simulation/lnaSimple/spectre/schematic/netlist folder. After hitting netlist and run, do you get warnings or errors in icfb? What is cadence doing during that one minute?
cds_root will find the path to the argument. since icfb and icms are in the same folder (.../IC/tools/dfII/bin) it shouldn't matter. Also be sure to use ` and not ' around the command. rfExamples folder should be set in cds.lib not as an environment variable unless your cds.lib has something along the lines of DEFINE rfExamples $CDS_rfExamples. Simpler way is to add this line to cds.lib (some useful example directories)
#EXAMPLE LIBRARIES
DEFINE US_10ths $CDS_HOME/tools/dfII/samples/cdslib/sheets/US_10ths
DEFINE rfLib $CDS_HOME/tools/dfII/samples/artist/rfLib
DEFINE rfExamples $CDS_HOME/tools/dfII/samples/artist/rfExamples
DEFINE pllMMLib $CDS_HOME/tools/dfII/samples/artist/pllMMLib
DEFINE pllLib $CDS_HOME/tools/dfII/samples/artist/pllLib
DEFINE passiveLib $CDS_HOME/tools/dfII/samples/artist/passiveLib
DEFINE bmslib $CDS_HOME/tools/dfII/samples/artist/bmslib
DEFINE ahdlLib $CDS_HOME/tools/dfII/samples/artist/ahdlLib
DEFINE aExamples $CDS_HOME/tools/dfII/samples/artist/aExamples
DEFINE avTech $CDS_TOP_DIR/ASSURA/tools/assura/etc/avtech/avTech
DEFINE functional $CDS_HOME/tools/dfII/etc/cdslib/artist/functional
these variables, CDS_HOME and CDS_TOP_DIR are specific to my site, maybe your variables are different. CDS_HOME is the same as result of cds_root icfb. CDS_TOP_DIR is the directory where all your cadence tools are installed (i.e. CDS_HOME can also be CDS_TOP_DIR/IC and MMSIMHOME can be CDS_TOP_DIR/MMSIM, etc).
in .cshrc, try:
setenv PATH $PATH:$MMSIMHOME/tools/bin:$MMSIMHOME/tools/dfII/bin:$CDSHOME/tools/bin:$CDSHOME
/tools/dfII/bin:$CDSHOME/tools/java:$CDSHOME/tools/java/bin
be sure to define MMSIMHOME and CDSHOME before defining PATH
are you using .cshrc designed for the same version of IC that you are using?
apprentice
Reply #6 - May 8th, 2009, 9:39pm
I post the netlist and log first. I'm trying other suggestion.
Thanks.
1. the netlist  (remove this duplication, see below the recreated one)
2. .cshrc version seems match IC version I'm using. See below. I'm using SUNOS
# Variables: ICVer     = ICFB version
#            ASSURAVER = Assura version
#            CalVer    = Calibre version
alias cdsdoc cdnshelp
set CADOS = `uname | tr '[a-z]' '[A-Z]'`
echo "OS      =" $CADOS
if("$CADOS" =~ *SUNOS*) then
  #setenv ICVer IC446
  #setenv ICVer IC446_MSR11
  #setenv ICVer IC5033
  #setenv ICVer IC5033usr3r4
  setenv ICVer IC5141_USR4
  setenv MMSIMVer MMSIM60
  #setenv ASSURAVER ASSURA313usr1
  #setenv ASSURAVER ASSURA316
  setenv CalVer cal_2005.1_10.20
endif
3. setenv PATH   in .cshrc
    SHELL=/bin/tcsh
    when I try
/tools/dfII/bin:
after run .cshrc,   it shows:
Bad : modifier in $ ($).
    Do I keep other PATH configurations when I append the new PATH configuration?
« Last Edit: May 9th, 2009, 11:26am by apprentice »
Reply #7 - May 8th, 2009, 9:59pm
apprentice wrote on May 7th, 2009, 7:37pm:
Show me the followings.
(1) Result of "ADE>Setup>Simulator/Directory/Host"
(2) Complete netlist("input.scs") which you can show and save it by "ADE>Simulation>Netlist>Display".
(3) Complete log file("spectre.out") which you can show and save it by "ADE>Simulation>Output Log".
apprentice
Reply #8 - May 8th, 2009, 10:48pm
thanks Pancho_hideboo.
1) screenshot attached
2) recreated netlist: input.scs
3) unfortunately the function is in grey color,  screenshot attached
/ Generated for: spectre
// Generated on: May  8 22:38:49 2009
// Design library name: myrfExamples
// Design cell name: lnaSimple
simulator lang=spectre
global 0
include "/opt/eda/cds/IC5141_USR4/tools/dfII/samples/artist/ahdlLib/quantity.spectre"
include "/disk01/home/cdsmgr.sun/ahdlcompany/quantity.spectre"
parameters prf=-10
// Library name: myrfExamples
// Cell name: lnaSimple
// View name: schematic
V8 (power 0) vsource dc=15.0 type=dc
R0 (net39 out) resistor r=50
R23 (power net39) resistor r=150
R22 (net9 0) resistor r=705m
R3 (net11 net20) resistor r=1K
R21 (net20 0) resistor r=470
R19 (net27 net14) resistor r=500
R6 (net24 out) resistor r=1K
R10 (0 net27) resistor r=2K
C25 (in net20) capacitor c=1.000n
C24 (net39 0) capacitor c=100.0n
C23 (net20 net24) capacitor c=1.000n
C22 (net27 0) capacitor c=100.0n
C21 (out net28) capacitor c=100.0n
PORT0 (net28 0) port r=40 num=2
RF (in 0) port r=40 num=1 type=sine dbm=prf sinephase=0 freq=900M dbm2=prf \
       ammodindex=0.0 ammodfreq=10M ammodphase=0 mag=1 phase=0 xfmag=1 \
       pacmag=1 pacphase=0 fundname="frf"
Q4 (out net20 net9 0) NPNlower
Q3 (net11 net27 net39 0) generic_pnp
Q2 (net14 net14 power 0) generic_pnp
   checklimitdest=psf
pss  pss  fund=900M  harms=10  errpreset=moderate  annotate=status
saveOptions options save=allpub subcktprobelvl=2
apprentice
Reply #9 - May 8th, 2009, 10:51pm
3) screenshot
Reply #10 - May 8th, 2009, 10:57pm
apprentice wrote on May 8th, 2009, 10:48pm:
If you recreate netlist, run simulation again.
And in your netlist, no model file for BJT is included.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1205223090/1#1
Here "rfModels.scs" is included.
Show me your "ADE>Setup>Model_Libralies".
Show me your "ADE>Setup>Simulation_Files".
Run simulation again.
oermens
Reply #11 - May 9th, 2009, 5:37am
apprentice wrote on May 8th, 2009, 9:39pm:
   SHELL=/bin/tcsh
   when I try
/tools/dfII/bin:
Sorry my syntax was also wrong, i was mixing zsh and csh syntax. Refer http://root.cern.ch/root/EnvVars.html. So you should be using
set path = ( $path $MMSIMHOME/tools/bin $MMSIMHOME/tools/dfII/bin $CDSHOME/tools/bin:$CDSHOME/tools/dfII/bin $CDSHOME/tools/java $CDSHOME/tools/java/bin ) as before. Make sure everything is on a single line. You don't set MMSIMHOME or CDSHOME in you .cshrc, are you running another script to set these variables, or this is just small part of your .cshrc?
pancho_hideboo wrote on May 8th, 2009, 10:57pm:
This can also be the case if the simulation is not successful. I'm not sure why the simulation proceeds without include files. Are you using one of the gpdk's? I think alot of the appnotes are written for gpdk180, in which case you should also include its model file. If you installed the kit correctly, this should be taken care of by the .cdsenv template of the pdk, and you should set the environment variable CDS_LOAD_ENV=CWDElseHome (loads CWD/.cdsenv if it exists, or else ~/.cdsenv, if it exists). As requested, please attach your input.scs and spectre.out files.
Reply #12 - May 9th, 2009, 6:16am
oermens wrote on May 9th, 2009, 5:37am:
No. This example doesn't use "gpdk".
Include "$CDS_INST_DIR/tools/dfII/samples/artist/models/spectre/rfModels.scs" as model file.
Don't show same "input.scs" three times.
oermens
Reply #13 - May 9th, 2009, 7:12am
It seems he has a model file specified, otherwise he would receive the message in output log:
Problems encountered during simulation.
Use the Simulation->Output Log menu for more information.
I loaded the lnaSimple example and simulated using pss analysis and found no errors. I followed pancho_hideboo's instruction to load $CDS_INST_DIR/tools/dfII/samples/artist/models/spectre/rfModels.scs as the model file. I don't know which document you refered to in a previous post, but the voltage gain should be 10dB if my simulation is correct?
Reply #14 - May 9th, 2009, 9:49am
oermens wrote on May 9th, 2009, 7:12am:
"SpectreRF user manual".
Maybe correct.
Pages: 1 2 3
