Jul 21st, 2024, 4:22am
Pages: 1 2 3
can't plot any data (Read 28047 times)
Re: can't plot any data
Reply #30 - May 13th, 2009, 3:52am
apprentice wrote on May 12th, 2009, 9:57pm:
I also tried a DC analysis which shows similar problem - no output.
Have you ever run Cadence Spectre correctly using other circuits than rfExample ?
Try to run Spectre from unix command line without using ADE.
Reply #31 - May 29th, 2009, 1:18am
Go to the ~/simulation/lnaSimple/spectre/schematic/netlist directory in UNIX and type "./runSimulation" (there should be a script called runSimulation in the directory).
It may be that there is some problem with shared libraries or something similar that means that the simulator can't even start - hence a log file is not being produced.
Then tell us what it says...
apprentice
Reply #32 - May 29th, 2009, 10:00pm
31> ./runSimulation
./runSimulation: spectre: not found
32>
Hi Andrew,
  The above is what it says.
  I will keep trying until we have new system.
thanks
apprentice
Reply #33 - Sep 21st, 2009, 5:31pm
hi all,
  I just got new system. The RF examples can run without problem.
thanks
« Last Edit: Sep 21st, 2009, 7:49pm by apprentice »
Pages: 1 2 3
