Go to the ~/simulation/lnaSimple/spectre/schematic/netlist directory in UNIX and type "./runSimulation" (there should be a script called runSimulation in the directory).
It may be that there is some problem with shared libraries or something similar that means that the simulator can't even start - hence a log file is not being produced.
Then tell us what it says...
