Jul 18th, 2024, 3:28pm
analysis using cadence virtuoso in IBM PDK cmos10lpe design kit (Read 3337 times)
Mahyar
May 08th, 2009, 5:10pm
I am trying to simulate a very simple differential amplifier using cadence virtuoso (IBM PKD cmos10lpe) design kit. First I built my schematic then I made a cell view (symbol) out of it in order to be able to instantiate.
I built a test bench and I put the symbol of my differential pair into it and everything is ok when I save and checked it. but when I do the DC analysis and try to see annotate the DC points, I can't see any values in the input and out put of my  differential pair. As if it is not connected or I don't know what is going wrong?
oermens
Re: analysis using cadence virtuoso in IBM PDK cmos10lpe design kit
Reply #1 - May 8th, 2009, 6:43pm
What version of IC and MMSIM are you using? Is the simulation actually successful? Can you post your output log? Does anything show up in Results Browser dc-op? Have you tried simulating the diffamp schematic cellview on its own (i.e. not a testbench)? Can you do Results->Direct Plot->DC and obtain voltages at the input and output of the symbol?
Reply #2 - May 8th, 2009, 10:17pm
Mahyar wrote on May 8th, 2009, 5:10pm:
"DC Node Voltages" are different from "DC Operation Points".
And "MATLAB" are different from "Simulink".
Do you mean "DC Operation Points" truely ?
Show me your "symbol view".
Do you surely attach "cdsTerm()" as interpreted label ?
« Last Edit: May 9th, 2009, 12:01pm by pancho_hideboo »
Ian
Reply #3 - May 11th, 2009, 5:24am
You may see the DC result, if you go inside the differential amplifier block and annotate the DC operating points there.
