Aug 16th, 2024, 2:24am
Verilog-A/MS (Read 7452 times)
Dracon
Verilog-A/MS
May 09th, 2009, 1:22pm
Does anybody have any simulator summary that supports Verilog-A and Verilog-AMS from diffrent companies and their advantages and disadvantages?
thx
jbdavid
Re: Verilog-A/MS
Reply #1 - May 11th, 2009, 1:23pm
only rudimentary: - and from my point of view
  • Cadence: AMSD - my workhorse for nearly 10years - they even support fast transistor sims
  • Dolphin Smash: low cost, has an evaluation version I think.
  • GNUCAP: free - but not full featured yet
  • Synopsys VCS-Nanosim: Not integrated into ADE, might not support true mixed signal model styles - built on a premier Fast Spice.
  • Mentor - EldoAMS - VHDL centric model
  • others?
jbdavid
Re: Verilog-A/MS
Reply #2 - May 11th, 2009, 8:40pm
jbdavid wrote on May 11th, 2009, 1:23pm:
  • What do you mean by "might not support true mixed signal model styles" ?
    jbdavid
    Re: Verilog-A/MS
    Reply #3 - May 14th, 2009, 6:34pm
    What I mean by might not support true mixed signal model styles
    is that I've not heard satisfactory answers to my questions about using always and analog blocks in the same model.
    -- What I've heard they support is Verilog + Verilog-A
    Which I don't consider satisfactory for my normal purposes..
    It hasn't helped that SNPS laid off my main contact with those guys..
    jbdavid
    Re: Verilog-A/MS
    Reply #4 - May 16th, 2009, 3:56am
    jbdavid wrote on May 14th, 2009, 6:34pm:
    There is no such limitation.
    "Nanosim+VCS" supports full Verilog-AMS surely.
    However I feel an implemenation of IE(Interface Element) is poor.
    jbdavid
    Re: Verilog-A/MS
    Reply #5 - Jun 1st, 2009, 6:00pm
    I've not heard this from an SNPS AE,
    nor have I seen this.
    so you may think "surely" but I'm from Missouri. Show Me.
    Jonathan
    jbdavid
    Re: Verilog-A/MS
    Reply #6 - Jun 8th, 2009, 1:31am
    jbdavid wrote on Jun 1st, 2009, 6:00pm:
    Verilog-AMS has been supported since "VCS2006.06SP2".
    Re: Verilog-A/MS
    Reply #7 - Jun 8th, 2009, 1:35am
    Unsupported Features.
    jbdavid
    Re: Verilog-A/MS
    Reply #8 - Jun 23rd, 2009, 2:04pm
    the $dist functions are quite useful..
    as is Detailed discipline resolution.. Which, when I run anything in analog mode is what I use..
    Other than that its a good start..
    and I might be able to get it to work in some cases.
    But I would probably chafe at the restrictions..
    Thanks for the info..
    jbdavid
    Re: Verilog-A/MS
    Reply #9 - Jun 24th, 2009, 4:44am
    There is an issue about current "Nanosim+VCS".
    Current "Nanosim+VCS" does not have mixed-signal data format such as "sst2".
    So we have to treat two files, VCD and FSDB.
    CosmosScope can handle these.
    http://www.designers-guide.org/Forum/YaBB.pl?num=1231424371/1#1
