Berti
Hi Jsun,
I had recently a similar problem. The reason was that those id##ts from the fab defined the required view for simulation depending on the simulator (spectre-> spectre view, spectreverilog -> spectreverilog view etc.)
Adding
-------------- UARTspectreVerilogStopViewList="spectre" setq UARTStoreMenusInCurrent t loadi(strcat(getShellEnvVar("UNICAD_KERNEL_ROOT") "/Uker.ile")) ---------------
in your cds.init file should work-around the problem.
Cheers
