Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 17
th
, 2024, 12:30am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Switch cap simulation in hspice
Previous topic
Next topic
Switch cap simulation in hspice (Read 6699 times)
raja.cedt
May 13
th
, 2009, 8:16am
hi,
can any body please tell me how to simulate switch cap circuit in hspice?
Rajasekhar.
IP Logged
Re: Switch cap simulation in hspice
Reply #1 -
May 14
th
, 2009, 7:06am
Umm ... get a netlist, put in a .tran analysis statement ... ?
What are you trying to do?
IP Logged
raja.cedt
Reply #2 -
May 14
th
, 2009, 8:02pm
hi,
but i want to do ac analysis, then how to give clock?
rajasekhar.
IP Logged
Reply #3 -
May 15
th
, 2009, 4:36am
I think you need a PAC (periodic ac) analysis. Maybe you can use hbac (harmonic balance ac). See if you can find an app note on SolvNet.
IP Logged
cmos.analogvala
India
Reply #4 -
May 16
th
, 2009, 2:52am
Is possible to do simulations similar to PAC or HBAC in Cadence Spectre . .
-CA
IP Logged
Reply #5 -
May 16
th
, 2009, 3:03am
cmos.analogvala wrote
on May 16
th
, 2009, 2:52am:
HBAC which Geoffrey_Coram means is an analysis of HSPICE RF.
"Multitone Harmonic Balance AC Analysis (.HBAC)"
http://www.ece.rochester.edu/courses/ECE222/hspice/hspice_rf.pdf
In HSPICE(not RF), you can use combination analysis of ".AC", ".Noise", and ".SAMPLE" analysis, although it is not accurate evaluation.
Also see
http://www.designers-guide.org/Forum/YaBB.pl?num=1241681618/1#1
http://www.designers-guide.org/Forum/YaBB.pl?num=1210932698
http://www.designers-guide.org/Forum/YaBB.pl?num=1215093196/1#1
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
