Jul 17th, 2024, 3:26pm
Specify temperature of the chip in Spectre (Read 5708 times)
cmos.analogvala
India
May 29th, 2009, 11:53pm
There are three ways to specify temperature in simultions in Spectre Cadence.
1. Change trise of the deivce in its properties
2. Change temperature in setup->temperature in ADE
3. Change dtemp in model file
What are the differences between all these ?
-CA
Re: Specify temperature of the chip in Spectre
Reply #1 - Jun 7th, 2009, 10:36pm
Set ΔT between a specific instance and TEMP.
TEMP
Set ΔT between a specific component and TEMP.
Yawei
Reply #2 - Jun 8th, 2009, 7:00am
If you're trying to get all the devices in your circuit, then 2 is the most efficient, because it's one change.  3 requires a change for every model, 1 requires a change for every instance.  However, if you want different instances to have different temperatures, then 1 is your only option.
For a bug-free simulator, all three should give the same answer.
cmos.analogvala
India
Reply #3 - Jun 18th, 2009, 8:32pm
I am simuating my circuits using spectre. I see different results for option 1 and option 2.
Option 2 shows higher degradation in current with increase in temperature.
Which one to believe ?
-CA
Reply #4 - Jun 19th, 2009, 4:57am
That sounds like a bug to me.  Can you try options 1 and 2 on just a single transistor and check the id-vd plot?
Hmm, now I'm remembering ... in at least one foundry model library, I think I saw the circuit temperature used in the subckt, and maybe trise was omitted from the formula. (I think the temperature update equation was more complicated than what's available built into the resistor or something.)
I'd suggest just a sanity check on the transistors with the id-vd plot, then try the resistors, or open the model library file in a text editor and look at those subckts.
cmos.analogvala
India
Reply #5 - Jun 23rd, 2009, 9:15am
Problem Solved ...
The reason was inaccurate model card which was of the older version. With the new version of the model card I found exactly same results for ID-Vd of transistor for option 1 and option 2.
Thanks a lot ..
CA
